Power Valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2006, 09:03 AM
StevenC's Avatar
Power Valve?
What power valve should I use in a holly carb on an engine thats pulling 15 vacuum?
What is the correct equation for this? I dont understand the manual.
Thank you
Old 01-20-2006, 10:01 AM
If that is your cruise vac reading I'd start with a 10. If that is idle vac I'd put in a 8.5. There aren't a lot of choices really, that's about it. An 8.5 may give you a tad better throttle response or it could be a tad lean a certain throttle positions. It PV is simply a tuning device that begins to flow extra fuel at a preset loading on the engine based on vacuum.
Power Valve Blowout novatech Engine 8 09-27-2005 11:18 AM
Demon Power Valve calculation? underdog305 Engine 18 02-03-2005 11:45 AM
Changed jetting, power valve...still runs terrible BrackneyC Engine 3 04-05-2003 05:52 AM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 08:59 PM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 02:36 PM
