Power Valve Selection
I am trying to choose the correct power valve for my engine, and I have a small idea of how to do it, and I know it has something to do with the vacuum that the engine produces at idle. I am getting 6" of vacuum at idle, because of the camshaft that I have, and I know the power valve that I installed when I built the carb is probably for an engine producing 15" of vacuum or more. Does anybody have any ideas or know the correct way to figure after you measure engine vacuum
thanks
sbc 400
RPM Range: 3,500-7,000
Intake Duration at 050 inch Lift: 244
Exhaust Duration at 050 inch Lift: 254
Duration at 050 inch Lift: 244 int./254 exh.
Advertised Intake Duration: 302
Advertised Exhaust Duration: 312
Advertised Duration: 302 int./312 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.533 in.
Lobe Separation (degrees): 114
Sportsman II heads 2.1 intake 1.8 exaust (I think)
trw 2477 pistons .145 dome
Approximate 11.65 static comp.
