Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power washing engine?
Old 04-01-2011, 03:38 PM
timothale timothale is online now
Wiki Edits: 27
power wash
I've got a 3500 psi washer we use to keep the Farm and Construction equipment clean, We usually clean every thing we can before taking it in, I cleaned the backhoe engine, in the tractor first , ran it a little to check for oil leaks actually to see where it was leaking before pulling it, then took it in since I did not have the special tools needed. We do the Cleaning and inspection, then stamp all the parts before taking them in. I don't want a crank that has been welded exchanged for mine that just might need a polish. The shops either hot tank , or use the "Dish Washer" style cleaner as part of their process.
