Power Window Conversion Kit Recommendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2010, 11:44 AM
kbuhagiar's Avatar
47 Plymouth Special Deluxe
Hello Folks,
Being as I will be removing my door panels soon, I figured I might as well look into the possibility of converting my 47 Plymouth to power windows.
(Besides, Christmas is just around the corner! )
The Plymouth already has a bank of 'wireless' modular door contacts on each door (due to a previous remote door lock installation), with vacant positions, so I expect it would make the installation & wiring that much easier.
There appear to be quite a few kits out there; any recommendations? Tips or tricks? Positive and/or negative experiences with particular kits and/or suppliers?
Thanks in advance for you opinions and advice.
Cheers, Ken
Old 11-29-2010, 03:02 PM
Something that I have done in the past is to do a junk yard search for cars with power windows. I find one that is of good quality and seperate the metal inside panel of the door from the door shell. I get all of the parts for the window. This usualy means cutting the metal around the perimeter. I then weld/graft it in to the door that I want the power windows in. This is not for someone with limited experience but it does a great job and it is cheap. You will want to re-use the window track that is in the Plymouth and just attach the new regulator assembly to it. A lot of fabrication with this method so you may want to just buy a kit.
Another thing that you can do is what this guy does,
http://www.youtube.com/watch%3Fv%3D_...VfbFXznhhi6ggQ
LOL
Old 11-29-2010, 06:40 PM
302 Z28's Avatar
Do not buy a kit that uses a coil inside of a tube driven by a motor. IMO they do not work very well for an extended time. Go for the kits that use a typical window regulator they work the best. I have worked with Nu Relics kits before and like them very much.
Vince
power window conversion? 1969f-100 Interior 5 06-19-2008 08:57 PM
wiring a 3 switch kit for power windows?? doncase Electrical 7 06-11-2007 09:24 AM
Chev truck power window issue ghomer Electrical 6 01-05-2007 04:50 AM
Brake lines for conversion kit??? ChevyLuv Suspension - Brakes - Steering 9 09-26-2002 08:36 AM
Stick shift conversion kit cvc505 Transmission - Rearend 1 08-16-2002 09:43 PM
