Power Window/Door locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2003, 07:28 PM
Screwy Lewy's Avatar
New Member
I have just wired and installed AutoLoc Power windows in my Studebaker Camstar pickup. I tapped into the power of the window circut to avoid running another wire into the door. I just use the door solenoid to "pop" open the door by pushing a button SP momentary switch. Should I operate the solenoid by the Positive wire or by grounding the circut and wiring the solenoid HOT ie should I solid wire the ground or the positive?
Thanks
Screwy Lewy
Old 12-20-2003, 06:13 PM
Tazz
don't the installation instructions suggest using the ground??
Todd
Rat Rods Rule!
Old 12-22-2003, 12:23 AM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Screwy, on a soleniod it doesn't mattter as long as you have good power and groung. The wires can be either way. Autoloc has a real great tech line too! Ray (Autoloc dealer)
Forgot to tell you, you can use ! power source for all the acc. it the door as long as the right gauge wire and fuse or breaker can handle whatever is in the door. Only need 1 power wire. Ray
