Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power window kit
Old 09-30-2011, 10:37 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Use your old Plymouth window riser mechanisms. Cut off the crank handle and gear and weld on a bracket to adapt 80's Ford power motors. Dirt cheap @ Pick-A-Part and better than any after market Chinese risers out there. See here and here.
