-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   power window kit (http://www.hotrodders.com/forum/power-window-kit-206386.html)
SmileGuy49 09-30-2011 11:59 AM
power window kit
Does anyone know where I can get a good power window kit for my 49 Plymouth?
35terraplane 09-30-2011 12:15 PM
Power window
Welcome to the site. Look up kits on the Internet, it will give you a range and you can pick from there.
Bob
lanier ledford 09-30-2011 01:02 PM
power windows
try Specially Power windows in mid Georgia.
DanTwoLakes 09-30-2011 02:19 PM
Here is the link to their web site: CLICK HERE
SmileGuy49 09-30-2011 02:58 PM
Guys thanks for the info. Ouch though. I did not expect $700 for a 4 window application. I did a little searching on the net and found kits for around $300. Has anyone tried these out? There is a 2 door kit from EZ wiring that is about $150 and they said I can buy two kits in order to control 4 windows.
Thoughts?
27Tall T 09-30-2011 09:33 PM
:) I've used the EZ window units in my '32 and they work well for me. The only draw back is that they use metric bolts.
willys36@aol.com 09-30-2011 10:37 PM
Use your old Plymouth window riser mechanisms. Cut off the crank handle and gear and weld on a bracket to adapt 80's Ford power motors. Dirt cheap @ Pick-A-Part and better than any after market Chinese risers out there. See here and here.
ogre 10-01-2011 11:58 AM
i retrofitted 06 dodge durango front window regulators into my 58 chevy pickup. they were free :thumbup:
i used the front regulators because they were scissors type. the backs are single arm.
