Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power window motor for shaved door open?
Old 07-03-2012, 03:52 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
I've had pretty good luck with the "Plastic Dip"...... the stuff you dip pliers and screwdrivers into, to put a rubber coating on the handles. Wire it up with connectors on the wires with enough wire to allow you to dip the whole thing in the plastic dip ......one or two dips puts a nice thin coating on it and after it dries you can use a razor to allow the solenoid rod to move in and out but still have a seal...... well sort of.
