power window motors - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2004, 12:43 PM
montea's Avatar
tryn to learn
power window motors
in my 82 grand prix both of my power window motors sound pretty loud and are pretty slow. i pulled the drivers side one out and it was just caked in grease at the bottom. after phoning napa and hearing its $93 for 1 i decided its not worth getting new. is there any way of getting mine to work better?
by taking it apart and cleaning and regreasing the inside will it help any? anything i can do to it?
i have everything to convert to manual windows but i would have holes were the power window switchs were in my door pannels.
Old 11-26-2004, 06:47 PM
cboy's Avatar
Last journal entry: Finished
Did you try bypassing the switch and seeing how the removed motor operates...if it still runs slow and noisy?
Always learning...and sharing what I've learned.
Old 11-27-2004, 04:48 PM
Old enough to know better
Make sure the window mechanism is free and moves easily. It should not get stiff anywhere.
Also, if the other option is buying a new motor, you can't loose to much by completely cleaning and lubracating the motor and mechanism.
