power window relay 64 caddy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2012, 12:45 PM
atotalnincompoop's Avatar
Last journal entry: 46 mercury bobber pickup
i am having issues with my 64 cadillac cdv windows, the wouldn't work at all so i changed the relay, now...they still don't work.
when i switch the system to emergency mode, which bypasses the relay, they work, when i switch it back to normal mode, the relay vibrates and the windows don't work.
with the ignition on, i put a test light on the red wire it has power and no vibration, when i touch the test light to the thinner blue wire which runs to the fuse panel, i get power and the relay vibrates, same thing with the white wire which runs to the window switches.
any thoughts?
Old 09-06-2012, 04:19 PM
EOD Guy's Avatar
Sounds like you have a loose or bad connection..... if the hot side of the coil has pwr, then it's prob the ground.
Old 09-08-2012, 05:32 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
X2 on the ground.
If the relay is not operating the windows won't run.
Wiring diagram would be nice.
vicrod
fuse for relay power? dar130 Electrical 4 03-28-2011 08:34 AM
power window relay banditedtion Electrical 1 08-13-2003 10:38 PM
Wanted: 1959-1964 GM (caddy, buick, olds, etc) POWER VENT WINDOW MOTORS KUSTOMRYDER Hotrodders' Lounge 0 03-15-2002 06:23 PM
Wanted: 1959-1964 GM (caddy, buick, olds, etc) POWER VENT WINDOW MOTORS KUSTOMRYDER Interior 0 03-15-2002 06:22 PM
Wanted: 1959-1964 GM (caddy, buick, olds, etc) POWER VENT WINDOW MOTORS KUSTOMRYDER Electrical 0 03-15-2002 06:21 PM
