power window suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2008, 06:29 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Have a 34 and a window is going up slow, I am wondering what to look for when I go to replace the mechanism. Meaning is there a brand that is best, better or the bomb , for reliability and good action up/down... Got the troubleshooting all figured out so I am just looking for BRAND information, cause I am sure there is a quality difference out here.
Old 01-31-2008, 07:00 AM
Before you replace what you have check or run a new ground. Most of the time the slow windows in aftermarket apps seem to be ground issues.
Larry
Old 01-31-2008, 07:06 AM
pepi's Avatar
Thanks Larry but I know what the problem is and it is not electrical or a dragging window in the channels . Example down is fine up is slow .. like a worn dry worm gear . Anyway I know the unit needs to be replace and replacement window units and there quality is the information I am seeking, thanks again/
Old 01-31-2008, 09:32 AM
302 Z28's Avatar
I am not sure if Nu-Relics makes mechanisms for a 34, but their products are first rate IMO.
Vince
Old 01-31-2008, 10:05 AM
powerrodsmike's Avatar
Wiki Edits: 161
I have installed at least 30 sets of Specialty Power Windows gear type regulators in 34 coupes as well as other type cars and never been dissapointed. IIRC it is part # 2416U.
We used SPW exclusively at Poli-Form. when building the replica 34's.
I never had good luck with the cable type. Window control on rounded window just wasn't there.
Many of those aftermarket regulators use a off the shelf motor..SPW uses a motor from an eighties GM product, last one I bought was from an 85 truck. Cost me 35.00 at the parts store. Have you thought about just replacing that?
Later, mikey
BE different....ACT normal.
Old 01-31-2008, 10:13 AM
pepi's Avatar
Later, mikey
Good idea on the motor replacement, did not know that the regulator had serviceable parts, think I will look into that. I was going to try and stay with the same type of regulator, not needing to reinvent the wheel here, just a good repair is all I am after.....
Old 02-01-2008, 01:00 PM
Give NuRelics a try. First rate quality and bolt in. You can't do better.
Power window motors Lthompson General Rodding Tech 6 11-13-2007 11:36 PM
Power window problem 2ManyCars Electrical 5 08-03-2005 05:49 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
power window relay banditedtion Electrical 1 08-13-2003 10:38 PM
Power Window Problems APACHEMAN Electrical 1 08-08-2003 01:52 PM
