Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power window will not go up
Old 03-02-2011, 05:46 PM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by eloc431962
Probably the window regulator hanging up on you. JMO
Cole
This is a very good possibility.
If it is sticking or stuck, you should be able to push the window switch and see the dome light "dim down" just a little. This would be a good indication that the window motor is getting power and is just stuck.try it with the engine not running , the light will dim a little from the voltage drop the motor is creating. with the engine not running the alternator cant make up the difference which makes the dome light test work a little better.
