Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power window will not go up
Old 03-02-2011, 07:25 PM
timothale timothale is offline
Wiki Edits: 27
relay corrosion
I had problems fixing a Ford pickup. the relay terminals were corroded. I would show power with a test lite but it would not get enough amps to move the windows. corrosion problems can be hard to find. I used jumper cables from the battery to the motors to check them out. then knew they were ok. and started tracing back the wiring.
