Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power window will not go up
Old 03-04-2011, 11:44 AM
maddogmodl maddogmodl is offline
Thanks for all the suggestions. The window was not stuck, when I removed the motor, the window would slide up and down easily. I tried jumping the wires on the drivers door switch and think I found the problem. The pass. door switch worked , when bypassing the drivers switch. Now I am waiting for a new switch. I will also take a look under the carpet just to see if that wire is waring through.
Thanks again
Bob
