Power Windows - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 07:19 AM
Power Windows
My drivers window works great. Passenger and drivers side rear didn't work buy you could hear motor running. My son put passenger side window down last night and now that one doesn't work either. But again, you hear motor running. Is it bad gears in motor, relay, or off track? Thank you guys in advance.
Old 05-01-2011, 07:42 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I don't know exactly what you are working on, but pull the door panels and have a look could be off track or stripped gears. I mean you did say you can hear the motor running correct ? JMO
Cole
Old 05-01-2011, 07:50 AM
sorry. 1996 Lincoln Towncar. Yes, you can hear motors running. When rear passengers side was put down there was no sounds of stripping gears. Door panels are tough to get off. But I know I need to check.
Old 05-01-2011, 02:54 PM
In most of the Fords I've taken apart the motor drives a cable mechanism that pulls the window frame up and down. If the cable breaks or a pulley fractures (they are sometimes made of plastic), the motor runs and nothing happens.
Bruce
Old 05-01-2011, 06:19 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Both of my old T-Birds (94-97) and my current Windstar (96)
have gears driven by something kind of like a lovejoy coupler.
There are 3 bean shaped plastic eggs that transmit the power from the motor to the motor gear.
These things disintegrate over time and need to be replaced.
There is a kit that has these little beans in it, but I have never used one.
I just flat replaced the motor.
Old 05-11-2011, 01:23 AM
I heard you can replace the beans with 5/16" or 7/16" nuts (I forget which), but I had already bought motors by then.
Old 05-11-2011, 08:21 PM
302 Z28's Avatar
Ford has a gear kit that will replace what is broken.
Vince
power windows rollenhard Interior 2 12-26-2006 07:48 PM
power windows oldnable Electrical 1 12-03-2005 09:45 PM
Power Windows and Power Locks grandprix601 Electrical 0 01-22-2004 08:56 PM
Power Windows jpspridd Electrical 2 11-06-2003 02:47 PM
84 Z28 power windows Rubberman2003 Electrical 12 06-29-2003 03:39 PM
