Power Windows 64' Galaxie - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 03:57 PM
I own a 2-door Hardtop 64' Galaxie with power(less) windows that will soon be for sale. However, before selling, I'd like to make those windows move. A couple weeks ago, only the Driver's side door window worked. After cleaning off the extremely dirty contacts underneath the swithces, both door windows becam opertational. But shortly thereafter, they both quit working and now I'm stuck with one window down. Complicating things is that I can't seem to find a power window motor for a 64 Galaxie. Any Ideas?
Thanks-
Well Ventilated
Old 02-15-2005, 04:06 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Do the motors run but nothing moves or is there no power going to them? Former is bad parts inside the gear box (fixable) and latter is still problems with your switches.
Old 02-15-2005, 04:26 PM
Motors are not running. It was as simple as rolling the window down, letting the car run for a few minutes, and having nothing happen when trying to roll it back up. The windows stopped working on different occasions as well. I suspect the motor in the passenger window has gone bad becasue it had not been working for a while when after cleaning the contacts it decided to come back to life for a few final runs before slowly petering out. THe Driver's side window, however was operating smoothly and at normal speed when it just quit. I tried tightening and retightening the screw holding the switch inplace with no success. So now I'm stumped. Any Ideas.
-Thanx
Old 02-15-2005, 07:55 PM
Wiki Edits: 21
Sounds like worn motor brushes if you are getting power past the switches. You may get lucky by tearing them apart and taking them to a small motor repair shop and ask for replacement brushes.
