power windows/auto locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 12:51 PM
I have an 87 chevrolet caprice and the auto locks will unlock but not lock. The power windows are also feeling pretty weak. How do I fix this and what do I need?
Old 01-18-2006, 07:53 PM
xk8 xk8 is offline
Window regulator and electric locks
Remove your inner door panel then clean all the lock actuating rods, window regulator tracks and arms with mineral spirits. Lube with white lithium grease. That should get everything working well. On my Cadi I had to drill out all the rivets that hold in the electric window regulator motor and mechanicals to remove clean and lube it. I used nuts and bolts to reinstall the unit. It now works great. Good luck!
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
Power Valves Ktaves1971 Engine 1 05-11-2004 07:35 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 09:49 PM
