powerband sbc 350..6" rod vrs 5.7 rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2002, 12:27 AM
Post powerband sbc 350..6" rod vrs 5.7 rod
Just wanting some personal feedback on the difference in "powerbands" on a sbc 355 using a 5.7 rod vrs a 6" rod. This motor will be used in a full steel 55 chevy with a 4.56 gear. It will be a 10.3-1 compression, 202 64cc heads,6" Eagle "H" beam rods, Eagle steel crank, vic jr,750 holley, a comp 520/540-292 solid cam. The low compression will hopefully make it more streetable with a 150 shot of juice when needed. Got a super t-10 4 speed now but may change to an automatic. Any suggestions on more needed torque??? THANKS DY
Old 11-08-2002, 09:01 AM
Post
Tell me about the tire type and size. I'll run the numbers through a performance simulator and help you streamline your efforts.
