Powerbuilt balancer installer problem
So I borrowed this kit from a friend and work and heated the balancer in the oven to 175 degrees. It went on nice and snug. When I went to remove the tool part of it stayed in the crankshaft snout! It is not broken, it just unscrewed. I really poor design if you ask me. It must have bottomed in the crank snout and that's why it is tight. User error? I dunno. So I figured, no big deal. I will just use the puller and remove the balancer to get at the threaded rod. NOPE. I can't center the tool and as soon as I started to tighten it it puts a side load on the bolts that screw into the damper. The threaded rod the puller is pressing against has a flat face.
Any ideas?
Those installers are usually universal and that's why it uses a stud to adapt different cranks to the installer. Is it possible the stud had a groove in one side for a flat head screwdriver and the stud was inserted backward?
The stud shouldn't be stuck in the crank snout all that tight. Is there any way at all to jam two nuts together then put a wrench on it? |
Still need help
Still can't get this stud out of the crank. On a mechanic's advice I got a cutoff wheel on a Dremel (only 2 threads worth of stud sticking out past the damper) and cut a deep notch in it. Then I got an impact driver with a bit that fit tightly. So far so good. Removed the fan, radiator and transmission cooler so I had some swinging room. I used a 2 pound hammer and wailed on it for 20 minutes. NOTHING. It never budged. Yes, the impact is set on LEFT.
Any ideas? All I can think of now is to carefully weld a bolt on it. |
| Balancer bolt problem! | Ballpeen | Engine | 6 | 10-19-2011 11:31 AM |
| Harmonic Balancer Installer | daveh | Garage - Tools | 4 | 11-17-2010 02:42 PM |
| Balancer problem | Zeater1 | Engine | 1 | 07-03-2005 10:35 AM |
| Powerbuilt Hot Rod Tools | atlantis | Garage - Tools | 4 | 01-13-2005 10:48 AM |
| Command Start installer book. | 4 Jaw Chuck | Electrical | 2 | 01-11-2004 08:19 PM |
