Powered bead rollers??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2010, 10:51 PM
35prog's Avatar
Last journal entry: More photos
I am looking into buying a powered bead roller. Was wondering if anyone here has one they can reccomend? Considering a Woodward Fab or Pro Tools. I know that Mitler Bros make a VERY nice unit, but with stand and 7 rollers is about 1300.00 w shipping. The Pro Tools unit will accept Mitler rolls (according to Pro Tools). Pro Tools quoted 1100.00 for unit with stand and 7 dies. The Woodward Fab unit is 960.00 w shipping. I feel any of these units would fit my needs, I just would like input from anyone who owns or uses one of these machines for their input before I spend $$$ on one.
Old 01-13-2010, 05:45 AM
deadbodyman's Avatar
Wiki Edits: 11
I know how hard it is to decide on a bead roller.Will this be your first? how often will you be using it? try this site www.metalmeet.com they have whole sections on bead rollers and any other metal shaping tools you might need.
Old 01-13-2010, 05:53 PM
35prog's Avatar
Yes, it will be my first. I have 2 cars of my own to do and do paint/body and fab work to support my addiction. I know I want a powered unit and will use it, just can't quite swing the jack for a Mitler Bros and was looking for oppinions on others.
Old 01-13-2010, 06:12 PM
Wiki Edits: 11
I got one from HF to get used to it.Its hard to pick out a good one for yourself until you get used to using one.forking out the cash is rough for me too so i put a motor on mine from a commercial sewing machine(it has a clutch),a gear reduction box...You can use a hydraulic motor from Surplus center, www.surpluscenter.com but with a 18"HF bead roller you can do a lot of stuff for 100.00 If you just take the crank off and put a steering wheel on it.
Old 02-23-2010, 10:35 PM
Wiki Edits: 27
powered roller
I bought the bigger HF bead roller... reinforced it with 2 x 2 angle iron ... added the HF atv 12 V winch and a jumper battery pack,... and the steering wheel... powered foreward and reverse.... some lathe work to the winch. all the info was on various Metalmeet threads.
Old 02-24-2010, 05:11 AM
Wiki Edits: 11
So ...have you went through ALL your scrap pile yet? when you get time check out the tipping wheels...... very handy...it'll take some lathe work because of the wierd shaft size on the HF roller....
Old 02-24-2010, 08:09 AM
Wiki Edits: 27
I lucked out
My son is an elect contractor and had his pickup bed trailer full of scrap wire. He bought the small throat HF bead roller and put on a high speed motor to smash the insulation to be able to get top price for clean copper. He gave me all the extra dies he didn't use. I reworked one die for him. . I heated it red then let it cool to try to anneal it . It still cut hard in the little lathe, harder than I thought it would be from HF. I have a copy of the mittler catalog roller dies. Just have to decide which ones to make.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Making dies and rollers to bend square tubing cboy Garage - Tools 20 11-05-2012 05:59 PM
Economy bead rollers Youngster Garage - Tools 4 08-08-2007 04:06 PM
harbour freight bead rollers Bad Rat Body - Exterior 11 07-15-2005 09:02 PM
High Powered Coil's Question Francis Electrical 3 04-12-2004 03:36 AM
