Powered fan rad or aluminum fins? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2013, 09:53 AM
Mitchman's Avatar
Grand Master of the Universe
700R4 in a 34 coupe.... Choices for cooling are either a powered fan unit under the frame or a finned aluminum tube also under the frame.
Pros... cons....? Gotta pull the pin soon.
Old 11-13-2013, 11:02 AM
astroracer's Avatar
If you can hang the cooler in the breeze it will work better but it may be to unprotected. Only you know how much space yo have and if the cooler will get good airflow. If you have to tuck it up a fan may be a good option. No way it will go in front of the cool pack?
Mark
Old 11-13-2013, 07:59 PM
Mitchman's Avatar
Mark
Yes, and no. I don't want it in front of the engine's rad (nor in it). It's bad enough we have to look at the A/C through the grill, but in the south summers can get a bit toasty and keeping it away from the other heat rads is a good idea.
How far should my fan be from the Rad? wickster Engine 9 06-18-2011 12:13 PM
what is the difference between a aluminum rad and brass/copper rad? Canadian78 Engine 21 04-19-2010 12:23 AM
Aluminum Rad malc Engine 3 09-24-2005 05:39 AM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 03:10 PM
Aluminum rad ? x007 Engine 24 06-03-2005 09:04 PM
