Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - powerglide
Thread: powerglide
Old 06-15-2011, 08:24 PM
anglia427 anglia427 is offline
im assuming this is a drag car,the 1.76 planetary will handle a lot more than the 1.82 carrier but they do hold up ok with a small block.besides a input shaft and high clutch hub a manual v/body and a dual ring servo.i would run a 6 clutch direct set up.there are some pump mods that should be done cooler bypass circut plugged,larger lube holes and converter charge mods also machining the stator for a roller bearing.check out TSR the owner is a friend carl monroe he has a very good book on modifting powerglides and he has any parts you will need
