powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2009, 06:33 PM
joeyb's Avatar
powerglide
hi guys i am workin on a 63 impala ss with my dad it has a aftermarked 350 with the original powerglide tranny. it was realy worn out so he got it rebuild and the guy screwed him over and f***ed it all up and what ever. but when he bought the car he got an extra powerglide with it but it is a later style non duel pump and has a longer tail peace with a diffrent spline. so now to the question lol i was thinking that we could just pop off the tails on them and the shaft and switch them is that possible and yes we know a th350 or an overdrive is better but this is what we have so thanks
joe
Old 11-25-2009, 08:25 PM
junior stocker's Avatar
Yes, you can swap to the shorter planetary setup, and extension housing. But, why not rebuild it yourself, they are very easy to do; the hardest thing is getting the steel speedometer gear off the tailshaft. You do know that you will have to swap out essentially the entire rotating parts assemblies? And, be careful not to mix and match 1.82 and 1.76 first gear ratio parts. Just happen to have a 25" Glide that came from a 63" 409 car; so I've hung onto it for many years waiting for just the right buyer to come along; someone looking for the numbers correct setup.
Old 11-25-2009, 08:27 PM
kleen56's Avatar
Back in the day, people use to laugh at the powerglide. Now they are very popular on the race track. 2 speeds is all you need to get to the end of the track. I'd keep the powerglide.
Old 11-25-2009, 08:40 PM
The PG is popular on the track when the motor's power band is matched to the RPM range that the car will see. Fewer shifts make for less lost time. That does NOT make it a good street trans, however. Why would you want only a 1.76:1 first gear in a heavy car?
powerglide questions pittbull7934 Transmission - Rearend 12 06-29-2009 11:17 AM
Transmission for a v/8 powered trike? Bad Rat Transmission - Rearend 31 02-17-2009 12:57 PM
Powerglide problem 58lincoln Transmission - Rearend 2 11-30-2008 09:46 PM
Powerglide trans to 400 Chevy motor K9sicem Transmission - Rearend 3 07-09-2006 09:43 AM
Powerglide street manners questions. RObs71Nova Transmission - Rearend 6 08-02-2005 10:21 PM
