powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 10:54 AM
Last journal entry: old 55
powerglide
how to determine if my pg trans come out of v/8 or 6 cylinder number on right side of pan c8b14n
Old 12-18-2010, 11:24 AM
Overdriv's Avatar
The number means it was built in Cleveland in 1968, Feb. 14th on the night shift.
I found this on the internet, there is all kinds of trans information on this board and the internet if you would just take the time to search for it.
Old 12-18-2010, 11:56 AM
powerglide
i thank you for that info i have looked all over and found that 1.82.1 ratio means 6 cyl and 1.76.1 means v\8 but i don't know how to find out ratio of my pg to determine if it came from 6 or v/8
Old 12-18-2010, 02:13 PM
junior stocker's Avatar
You are "sort of" in luck when it comes to Powerglides. It's going to be a fine spline output shaft being the year it is (as ID'd by the code on the pan). You'll need an outside caliper, and measure the diameter of the output shaft that's exposed. a 1.82 first gear unit will be 1.145, while the 1.76 will be 1.170. IF it's a course spline output those measurements are the same. Be aware they all take the same output shaft bushing and slip yoke. OR, you could pull the input shaft out, and measure the length of it; 1.82 is 12 5/8" long while a 1.76 is 12 7/8" long. Butch/junior stocker.
Also, it's not necessarily true about 1.82 being ONLY for 4 and 6 cylinders; they were also used with the 2 barrel 283 V-8 engines. Some six cylinders came with the 1.76, if used in police-taxi cab-rough service vehicles (yeah, a cop car with a six and a Powerglide, must have been in Mayberry with Barney Fife at the wheel).
Old 12-18-2010, 07:06 PM
powerglide
thanks a lot my man
Powerglide TV question woodz428 Transmission - Rearend 3 03-05-2010 09:45 PM
Transmission for a v/8 powered trike? Bad Rat Transmission - Rearend 31 02-17-2009 11:57 AM
Powerglide problem 58lincoln Transmission - Rearend 2 11-30-2008 08:46 PM
Powerglide street manners questions. RObs71Nova Transmission - Rearend 6 08-02-2005 09:21 PM
Powerglide, strength, conversion and misc' Venturat Engine 1 01-21-2003 09:52 AM
