-   -   powerglide (http://www.hotrodders.com/forum/powerglide-200265.html)
defilade 06-13-2011 12:53 AM
powerglide
what other components besides the clutch hub and input shaft should be replaced to make powerglide bulletproof
Crosley 06-13-2011 07:08 AM
Depends on the power you are using. Weight of car? Use of a transbrake?
defilade 06-13-2011 08:23 PM
stout powerglide
3300 GVW, no transbrake, zz430 crate engine
anglia427 06-15-2011 09:24 PM
p/g
im assuming this is a drag car,the 1.76 planetary will handle a lot more than the 1.82 carrier but they do hold up ok with a small block.besides a input shaft and high clutch hub a manual v/body and a dual ring servo.i would run a 6 clutch direct set up.there are some pump mods that should be done cooler bypass circut plugged,larger lube holes and converter charge mods also machining the stator for a roller bearing.check out TSR RACING.com the owner is a friend carl monroe he has a very good book on modifting powerglides and he has any parts you will need
defilade 06-27-2011 07:09 PM
pg
cool, thank you
