powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 12:53 AM
defilade's Avatar
2012
powerglide
what other components besides the clutch hub and input shaft should be replaced to make powerglide bulletproof
Old 06-13-2011, 07:08 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Depends on the power you are using. Weight of car? Use of a transbrake?
Old 06-13-2011, 08:23 PM
defilade's Avatar
2012
stout powerglide
3300 GVW, no transbrake, zz430 crate engine
Old 06-15-2011, 09:24 PM
p/g
im assuming this is a drag car,the 1.76 planetary will handle a lot more than the 1.82 carrier but they do hold up ok with a small block.besides a input shaft and high clutch hub a manual v/body and a dual ring servo.i would run a 6 clutch direct set up.there are some pump mods that should be done cooler bypass circut plugged,larger lube holes and converter charge mods also machining the stator for a roller bearing.check out TSR RACING.com the owner is a friend carl monroe he has a very good book on modifting powerglides and he has any parts you will need
Old 06-27-2011, 07:09 PM
defilade's Avatar
2012
pg
cool, thank you
Powerglide? 396chevelle Transmission - Rearend 16 02-09-2014 03:11 PM
powerglide joeyb Transmission - Rearend 3 11-25-2009 08:40 PM
Is there any value in an old powerglide? loyter Transmission - Rearend 7 04-27-2007 03:55 PM
Powerglide ?? Overdriv Transmission - Rearend 9 12-21-2005 07:33 PM
powerglide camnova Transmission - Rearend 2 12-12-2004 09:43 AM
