Powerglide to a 235? Bellhousing plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2007, 08:24 PM
Hey everybody!
I'm looking for whatever I need to mount a Powerglide to a 235 motor. It currently is mated to a 3-speed, which has the bellhousing.
Also, do I use a flex-plate as current models, or the old flywheel when using a Powerglide?
Thanks for the help! Mike
Old 01-11-2007, 08:29 PM
Wiki Edits: 31
this installation was done from the factory, using a huge cast iron bellhousing adaptor, uses a flywheel I belive.
Old 01-11-2007, 08:43 PM
Thanks Matt! Any ideas on where to find that kind of stuff?
Old 01-11-2007, 08:50 PM
Wiki Edits: 31
Ebay, also www.chevy'softhe40's.com might help you locate parts, or may have the parts, they keep a small invintory of used and NOS parts.
Old 01-11-2007, 09:24 PM
poncho62's Avatar
Wiki Edits: 5
moving this to tranny forum.
Old 01-11-2007, 11:18 PM
There's one on Ebay.
http://cgi.ebay.com/ebaymotors/1957-...QQcmdZViewItem
235 to powerglide...easy match???? sonnyb Transmission - Rearend 8 09-25-2006 11:21 PM
8BA flathead oil pan cleanout plate powerrodsmike Engine 0 09-13-2005 05:52 AM
1955 chevy 235 cam thrust plate captjosh Engine 1 05-26-2005 02:27 PM
Powerglide adapter plate Hood_lum Transmission - Rearend 1 12-29-2002 02:16 PM
235 Engine / Powerglide to 3 speed swap New2theart Engine 2 07-16-2002 07:22 PM
