Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - powerglide
Thread: powerglide
Old 09-09-2004, 08:06 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
A glide from behind a v-8 is a bit better if you are not going to freshen the trany.
You can determine the gear ratio of the planetary by measuring the diameter of the splined section that sticks out of the tail housing. A vernier caliper will work
there is a slight difference in diameter size from the 1.82 & the 1.76 gear ratios.
