powerglide to 350 speedo change? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2002, 09:15 PM
briwill's Avatar
Post powerglide to 350 speedo change?
I am replacing the powerglide in my 65 chevy PU with a TH350. How do I get the speedo to work? Will the cable fit the new trans or do I need an adaptor?
Old 11-12-2002, 02:31 PM
New Member
Post
Check out this link on how to determine what kind of speedometer gears you need. Hope it helps.
www.tciauto.com/tech_info/speedo_gears.htm
