powerglide...4.57 rear end gears... mix well? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2002, 07:29 AM
New Member
Post powerglide...4.57 rear end gears... mix well?
i have a rail job with a 292 inline six and 2 carter AFBs and many other good things,but powerglide too a 4.57? is that to low geared for a 1/8 of a mile?
Old 09-08-2002, 12:41 PM
Post
Determine expected MPH and RPM (be honest with yourself here) at the end of the 1/8 mile, measure tire Dia. and calculate gear ratio. That will get you the ratio you need and eliminate conjecture!!!
Old 09-08-2002, 03:48 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Post
Hey Six Shooter.
A ^ banger in a rail. Thats cool. I always wanted a V8 rail.
Anyway, I have a 2 speed in mine also. At 60 mph with a 2 speed and 30 inch tires, your cruising 3,071 rpm"s. I can run the 1/8th without problwems, so you should be alright. Try www.prestage.com and use there math calc. Itys easy, ande quick. Goodluck. Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 09-12-2002, 06:26 AM
New Member
Post
i apreciate the help yall. thanks
