Powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 08:25 AM
67 Nova 400sbc.4L60
Powerglide
I am inquiring about the mechanical flow through the Powerglide. ex. What is on in First then Second (Drive) as well as reverse gear. I can't fid it in any books. Thank You.
Old 05-10-2006, 09:20 PM
Low gear band is first
high gear clutch (in the drum) is second
Reverse clutch is the pack in the case (back of the trans)
Only one of these is on at a time.....ONLY ONE! If you have a transbrake valve body, the reverse pack is energized when the brake solenoid is energized, locking the trans internally.
This is the most basic trans for power flow. Good luck mastering it. Many fight this trans, few understand it....
Old 05-11-2006, 07:15 PM
67 Nova 400sbc.4L60
Powerglide.
Thank You For the info. I believe I have the problem solved. the hub in the Second (direct) clutch is for a four clutch pack . and the previous builder installed five . With Five friction plates the hub is too short and the last plate strips on the teeth. I took the clutch out of another Poweglide which has a wave plate , then a steel then alternatly four friction and steels. This is the way to go or purchase a hub that is longer such as used on 396 engines.
Old 05-11-2006, 08:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
aftermarket hubs are long enough and waaay stronger than OEM. Sonnax has them , other companies too
Old 05-12-2006, 09:50 AM
67 Nova 400sbc.4L60
Powerglide.
Thank You.
Powerglide street manners questions. RObs71Nova Transmission - Rearend 6 08-02-2005 09:21 PM
Newbie with powerglide problems robbrady Transmission - Rearend 0 02-06-2004 11:28 PM
Powerglide, strength, conversion and misc' Venturat Transmission - Rearend 5 01-21-2003 07:59 PM
Powerglide, strength, conversion and misc' Venturat Engine 1 01-21-2003 09:52 AM
powerglide to 2004r thedez Transmission - Rearend 1 06-11-2002 06:44 AM
