Powerglide and cam combo (Street-strip) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-10-2012, 01:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Coolrider View Post
I know! My mecanic friend says the same good things about the 700r4 so... I wanted to keep my fact. powerglide but... It seems that i won't have choice to set with that transmission i think. He's a transmission specialist with great knowledge in race track setup and wants to build one for me.
The PG is not good for acceleration in a heavier car, but the top speed is not affected one way or the other- it has a 1:1 ratio in Drive, same as a TH350/TH400, etc. So the top end speed is going to be the same, or maybe a little higher due to less frictional losses.
Where you can have the better of both worlds is to use a TH2004R or TH700R4 like mentioned already. They need help if stock to hold up well to a performance engine, but it can be easily done- for a price. Even a properly built TH350 or TH400 would be better for acceleration than the PG.
The thing is, you can cam yourself out of being able to use OD unless the rear gear ratio is very low- like 4.56 to 4.88. A 4.88 rear gear would give you a 3.42:1 ratio in OD. A 4.56 gear = 3.19, and that is about as low as you can go w/a relatively big cam w/o bringing the engine rpm down so far that OD becomes useless.
  #17 (permalink)
Old 12-10-2012, 12:53 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
I rarely post anything counter to Richard.I guess he is just answering the O/P's question.I does grade against me for any cam company to sell a cam for the "sound of it". It be begs the question what are we doing here??. Hate it.
  #18 (permalink)
Old 12-10-2012, 01:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thank you for your advice. I am going to speak about it to my friend mechanic. You helps me in my plan and, also, thanks a lot to techinspector1. I chose the 283THR7 Tumpr cam. So... with that setup, i should be satisfied. Thanks once again to all of you with your great knowledge.
Harold.
Hopefully your trans guy knows the ins and outs of the throttle valve (TV) linkage adjustment- this is uber critical to the transmission lasting and not self destructing right away. Links to info on setting a carb up to correctly operate the TV cable is here.
  #19 (permalink)
Old 12-10-2012, 01:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Harold.
Comp claims "...stock converter ok, best with 2000+ converter and gears...". I'd recommend at least 2500 stall and 3000 rpm stall would be even better if acceleration is important. The 2500 stall speed TC should be enough to keep it from pulling through the brakes at a stop sign.
Also, the distributor will need work to get enough initial timing w/o having too much mechanical timing. A stock distributor is just a starting point. Even an MSD distributor w/the black 18 degree advance bushing might not be enough. It's no big deal setting the distributor up, but it IS something that you'll definitely have to deal with before you're done.
What Is The Ultimate Street/Strip SBC Combo? (Updated) V8Guy427 Engine 5 04-04-2014 11:06 AM
454 street/strip cam select bigjohn.94 Engine 4 03-06-2012 08:25 PM
vortec 406 street strip cam help Big Reazon Engine 4 09-28-2011 10:10 PM
which cam for a street/strip 383 my87Z Engine 5 07-09-2011 02:43 PM
Whats The Ultimate Street/Strip Combo? V8Guy427 Engine 7 01-29-2004 07:09 PM
