Powerglide converter not slipping - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 11:15 AM
I have a 64 powerglide in my truck behind a 283. It has a hughes 2200-2500 stall converter. When i put it into gear it bogs the engine down to 400 rpm. When you try and break stall it it dosent rev past 600 rpm. The transmission has probably never been rebuilt in 15 years could it need a fresh build? I replaced the modulator valve with a new one but no change
Old 07-17-2011, 12:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is the engine stock or built up for performance?
When you drive the truck down the road, the engine runs good , plenty of power then?
Old 07-17-2011, 12:52 PM
It's pretty mild, comp 268 h cam, 600 edelbrock on top. It drives very well once its moving
Old 07-18-2011, 12:26 AM
SSedan64's Avatar
A 268H isn't exactly mild in a 283.
Duration @.050" 218/218, Lift .454/.454, Operating range= 1500-5500rpm in a 350ci Engine. In a 283ci it's probably more like 2000-6000rpm or higher.
You may need a higher stall. The stall in the TC will act smaller in a 283ci as most TC stall ratings are for 350ci to 454ci.
Example= 2200rpm = 350ci to 2500rpm = 454ci.
What do you have the Timing set at? Initial, Mechanical & Vacuum Advance?
Carb is also a little large for a 283.
Old 07-18-2011, 06:45 AM
Right now the timing is at 16deg base 37 total with vac advance hooked to manifold. When in gear the converter won't allow the engine to rev past 450 rpm with out moving the truck
Old 07-18-2011, 02:44 PM
SSedan64's Avatar
Sounds like the TC is just too tight for the 283.
May need to look at a 10" TC w/3000rpm stall to allow the 283 to stall around 2500rpm.
What rear Gear ratio does the Truck have?
Old 07-19-2011, 06:55 AM
Right now it has 3.90 s in the back. It drives well just sucks when in gear
Old 07-19-2011, 07:33 AM
Anyone thought of a broken sprag in the converter?
Old 07-19-2011, 09:37 AM
Would that be possible since its a brand new converter
Old 07-19-2011, 10:42 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
do you got fully advance @ 3000rpm or 5000rpm? sound to me that something is wrong does the Vacum clock open or is it stuck ore is the membran the rubbery peace incide broken?
Old 07-19-2011, 10:47 AM
Yep. Quality control no longer exists. My vote is for a defective converter.
Old 07-19-2011, 10:48 AM
New Converter, OK how loose was the old converter? You might want to contact the converter manufacter. They can provide you the information you need, you might want to ask if they can increase the stall speed based on your needs by re-working the internals. Might be cheaper than buying a new one - or they could possibly identify something wrong on the inside. A broken sprag causes direct drive, if you hit the brakes you would kill the motor, which that is not the case here.
Old 07-19-2011, 10:52 AM
Perfect Answer!
Old 07-22-2011, 10:14 PM
Well i found the solution. i think haha I phoned hughes and asked them what the problem was. They told me that well i should have used a 3000 rpm 10" converter and that what i was using was simply to tight for my "mild" cam hah. i guess a lesson learned.
Old 07-26-2011, 12:55 AM
I defiantly won't be buying any more glide converters. As far as the distributer goes my mallory one dosent allow the user to change the amount of advance.
Powerglide stall converter question? DEMONSPEED Transmission - Rearend 7 12-03-2009 09:32 PM
Tranny or torque converter? (th350 slipping) Mr. Y Transmission - Rearend 7 05-30-2009 01:17 AM
Converter slipping too much? 84Z Transmission - Rearend 2 05-01-2007 05:21 PM
Is this converter slipping too much? wickster Transmission - Rearend 2 07-18-2005 07:32 AM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 05:56 AM
