Powerglide electric shift/Trans brake valve body. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2008, 03:58 PM
junior stocker's Avatar
Do any of you out there know who makes the Powerglide Electric shift/Trans brake valve body. This actually has a solenoid mounted to the valve body that is used to make the 1-2 shift at a pre-set RPM from an MSD box, shift light, or similar means. It also had a trans-brake. This is NOT an air shifted or solenoid mechanism attached to the shifter, but it's all internal and "hidden". Putting together a Glide for a handicapped racer and have one of these valve bodies, bought used; and the seller did not know who makes it either. Both the electric shift solenoid and the trans brake solenoid work; I'd just like to know more about it. Thanks.
It is the same unit on page 166 of the "Powerglide transmission handbook" by Carl H. Monroe and published by HP Books. It gives credit to TSR Racing Products for the photo, but I can't find anything about it on that companies site on the Net.
Old 02-16-2008, 07:00 PM
Crosley's Avatar
Wiki Edits: 1659
apologies ,
I forgot in the PM , to mention two things.
Check with Turbo Action , they build some electric v-bodies.
second item... send a PM to Chazmac here on HR about the PG v-body you have.. The guy is a wealth of knowledge
Any photos of this v-body you can post??
Old 02-16-2008, 07:20 PM
e-shift glide
No pics on my end, but it's the same as I mentioned in the book noted in my initial post. Looks like FB Performance Transmissions and TSR Racing Products both have these setups, but I can't access any detailed info on either sites. I have sent an E-Mail to them both, maybe I'll hear something next week. I'll look at the Turbo Action site. Thanks.
Turbo Action does'nt list anything like it for the Powerglide.
Old 02-17-2008, 10:55 AM
Junior,
Go to your PM and get back to me. We can post results/info later if you wish...
Pictures would help!
Old 07-31-2008, 05:15 PM
glide ?
pm sent get back to me please joe
Old 07-31-2008, 08:16 PM
5.0joe79 if you sent me a PM I never got it....
Old 08-01-2008, 04:52 PM
sorry chazmac e-mail me back about this trans. joe5.0bonko@yahoo.com
Old 11-05-2008, 12:42 PM
Junior Stocker,
If you are still interested in pictures of an electric shift valve body or purchasing one. We build them in-house in our shop in Virginia.
***************.com
Last edited by Crosley; 11-05-2008 at 05:20 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 03-29-2011, 05:13 PM
trans-king,in galveston,texas.don't have current phone #.I have one in my racecar & it works great
constant pressure valve body maninacoupe Transmission - Rearend 2 10-24-2008 01:12 PM
constant pressure valve body (700r4) Boosted89RS Transmission - Rearend 4 11-05-2007 08:00 PM
Valve Body Question Bobwee Transmission - Rearend 4 09-16-2007 07:21 PM
AOD Valve Body ?s mustang66maniac Transmission - Rearend 3 03-15-2003 02:12 PM
C4 valve body mhaener Transmission - Rearend 0 12-26-2002 11:01 AM
