Powerglide filler tube?
Hi all,
Please see my project here. http://www.hotrodders.com/forum/jour...ge=1&reverse=1 I need to get a filler tube for my Powerglide, it's from my brothers 64 Parisienne and most likely the original box. My question is, will any filler tube from a Powerglide fit this? I.e. are the fittings on the housing the same? And also, does the angle of the tube differ much from model to model? I found this.. http://www.tciauto.com/Products/Comp...bes-mounts.asp With the Aussie dollar doing as poorly as it is, I want to make sure I get the right one, first go... Anyone got any advice on this? Cheers |
The first two are stock shape for all aluminum units. The tubes are designed to hug the tranny case/engine so as not to interfere w/ anything else on the car so either would be great on a street car like you are building. the other two on TCI's web site are for special applications and not what you want. All PGs have a simple rubber gasket on the tube that slips into the hole in the case. The only thing securing the tube in place is the little bracket welded on the tube that is secured to one of the bell-housing bolts. Get one of those with confidence!
| Plastic filler tips. | MARTINSR | Body - Exterior | 14 | 03-03-2009 05:11 PM |
| The most common mistakes made by the newbe working with plastic filler. | MARTINSR | Body - Exterior | 7 | 02-14-2006 10:21 PM |
| "Basic of Basics" How do you properly apply filler? | Centerline | Body - Exterior | 2 | 02-10-2006 12:22 AM |
| Filler tube leak | Deadtemple | Transmission - Rearend | 2 | 10-08-2003 06:39 AM |
