Powerglide & GM 7.5" Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2010, 06:45 PM
I am looking for ways to trim reciprocating weight on our powerglide and GM 7.5 rearend. We run a class that has limited horsepower on a dirt oval. Is anyone aware of a lighter ring gear and pinion avaliable for this rearend? I have found a book that talks about lightning certain gears insde the transmission. I am open to any ideas anyone has to help me achieve our goal. Thanks for the help.
Old 04-05-2010, 07:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The tranny and diff don't have reciprocating weight, but you can trim some weight from the ring gear to lighten it a couple ounces- but the gains are miniscule as I'm sure you're aware. That diff is weak already, I'd be very careful reducing weight there.
The Powerglide has all the parts in the aftermarket to build a tranny w/o any GM parts in it- there are all sorts of low-mass drums, etc. that are available for them.
A couple thoughts-
Wheel bearings, drive shaft weight, u-joint yoke and joint size can sometimes be reduced, along w/meticulous maintenance can all be looked at.
Unsprung weight reduction will always help. The rotor size and thickness, weight of the wheels, tire weight (prob. spec tires, though) can be whittled on.
The viscosity and type (synthetic) as well as the amount of lube can be changed to be less power consuming. This will hold true for the engine right on back to the diff.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
GM rearend casting number Wayne Wagstaff Transmission - Rearend 0 05-06-2007 12:57 PM
7.5" gm 10 bolt????? Vancouver Grand Prix Transmission - Rearend 6 05-27-2003 03:49 PM
9 inch Ford Rearend for my 94 Cadillac Fleetwood 94 CADFLTWD Transmission - Rearend 4 11-11-2002 05:33 AM
GM Rearend 39bowtie Transmission - Rearend 2 04-07-2002 11:05 PM
