powerglide guestion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 08:40 AM
powerglide guestion
how can i tell the difference between a 1.76 and a 1.82
Old 03-06-2010, 12:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
most reliable method I have found is to measure the out put shaft diameter with a vernier caliper .
Aluminum power glide , 27 splines on out put shaft
1.153 to 1.155 = 1.82 gear
1.170 to 1.173 = 1.76 gear
Old 03-06-2010, 05:29 PM
thanks. is there any other way to tell?
Old 03-06-2010, 07:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is the trans apart or together?
Old 03-07-2010, 08:11 PM
they are apart. which has the longer shaft?
Old 03-07-2010, 08:21 PM
12 5/8 inch is a 1:82
12 7/8 inch is a 1:76
that is the over all length of input shaft
Old 03-07-2010, 09:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The problem with using the input shaft length as a guide is some one may have swapped in the incorrect shaft years back.
if the trans are apart, it is easy to tell gear ratio.
The 1.82 gear carrier with attached out put shaft is a stamped steel piece.
The 1.76 gear carrier is forged looking , not stamped steel
Powerglide TV question woodz428 Transmission - Rearend 3 03-05-2010 09:45 PM
Transmission for a v/8 powered trike? Bad Rat Transmission - Rearend 31 02-17-2009 11:57 AM
Pontiac Powerglide shifter 67malibu Transmission - Rearend 2 12-17-2008 01:49 PM
Powerglide problem 58lincoln Transmission - Rearend 2 11-30-2008 08:46 PM
Powerglide street manners questions. RObs71Nova Transmission - Rearend 6 08-02-2005 09:21 PM
