Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powerglide Info request.
Old 10-09-2012, 07:19 PM
dgcantrellsr dgcantrellsr is offline
Originally Posted by Studebaker View Post
Greetings, I have a Powerglide Transmission question. I have a 1967 & later 1.76 glide {front pump only type) with a broken bellhousing. I also have a 65 Rear pump model 1.82 gear with destroyed plantary but a nice undamaged case. What modifications do I have to do to use the valve-body, 1.76 planatary gears, governer, drums and shafts in the earlier case and eliminate the rear pump feature. I know the reverse feed hole is different. What else? Thanks in advance for any help with this.
Gonna use it for racing or just street? What type valve body? Brake,manual,stock?
