Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powerglide Info request.
Old 10-13-2012, 11:19 PM
junior stocker's Avatar
junior stocker junior stocker is offline
Why don't you just use the earlier transmission case, pumps, and valve body, and swap in your sun drive gear/plate and planetary. The later planetary will have the rear pump pin drive hole in it, even though it was no longer used. You also have to use the later input shaft. There's no need to delete the rear pump; in fact you'll be able to push start the car if ever needed that way. Rebuild it, check all the clearances, go. Butch/junior stocker.
