Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powerglide Info request.
Old 10-14-2012, 11:29 AM
Studebaker Studebaker is offline
Jr Stocker, Thanks for the info. You obviously know PG's. It would be nice to have the push start rear pump feature. I read your other posting about converting to manual shift with the 1/4 copper tubing peice for the 1-2 shift valve. I will make this change as well as the double steel replacement for the wave cushion spring in the direct clutch.
