Powerglide Info request. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2012, 07:51 PM
Greetings, I have a Powerglide Transmission question. I have a 1967 & later 1.76 glide {front pump only type) with a broken bellhousing. I also have a 65 Rear pump model 1.82 gear with destroyed plantary but a nice undamaged case. What modifications do I have to do to use the valve-body, 1.76 planatary gears, governer, drums and shafts in the earlier case and eliminate the rear pump feature. I know the reverse feed hole is different. What else? Thanks in advance for any help with this.
Old 10-09-2012, 08:19 PM
Gonna use it for racing or just street? What type valve body? Brake,manual,stock?
Old 10-09-2012, 10:15 PM
powerglide
Will be for street use, prefer to have a auto shift valve body. Upgraded converter, about 2000 stall.
Old 10-13-2012, 11:19 PM
junior stocker's Avatar
Why don't you just use the earlier transmission case, pumps, and valve body, and swap in your sun drive gear/plate and planetary. The later planetary will have the rear pump pin drive hole in it, even though it was no longer used. You also have to use the later input shaft. There's no need to delete the rear pump; in fact you'll be able to push start the car if ever needed that way. Rebuild it, check all the clearances, go. Butch/junior stocker.
Old 10-14-2012, 12:29 PM
Powerglide
Jr Stocker, Thanks for the info. You obviously know PG's. It would be nice to have the push start rear pump feature. I read your other posting about converting to manual shift with the 1/4 copper tubing peice for the 1-2 shift valve. I will make this change as well as the double steel replacement for the wave cushion spring in the direct clutch.
GM rear end widths info Christmas gift request iceman36 Suspension - Brakes - Steering 9 12-03-2009 07:25 PM
Intro and request for info Allenz Introduce Yourself 1 10-29-2007 02:55 PM
23 t-bucket info request jimandbeca Introduce Yourself 3 01-07-2006 07:37 PM
Why was hinge info request dumped? Beenaway2long Hotrodders Site Suggestions and Help 6 10-14-2005 12:24 PM
348/409 info request Madd Syntst Engine 3 10-02-2003 08:58 AM
