Powerglide into a G-body? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2006, 06:49 PM
dripcandles's Avatar
Does anyone know about putting a powerglide into a G-body? I have a 1978 Cutlass Calais that has a spent metric tranny, and I can get a 1968 powerglide with a converter for $135. Is this a direct swap, or are there issues with this? Thanks for your input.
Old 12-04-2006, 08:17 PM
The Cutlass has a Chevy 305
The Cutlass has a Chevy 305, and the powerglide is from a nova.
Old 12-04-2006, 08:21 PM
poncho62's Avatar
Wiki Edits: 5
Its a bolt in, you will have to rig a kickdown linkage........and run a vacuum line for the modulator valve.....and play with the shift linkage.
I think you would be happier with a T350...............it bolts in too.
Old 12-04-2006, 08:23 PM
The 'glide will go in the hole, but you will probably have shifter and TV linkage issues unless you got ALLLLL of that stuff from the donor car.
Probably easier and cheaper to get a street/strip T350...
How to on Body Off Build? joeford Hotrodding Basics 3 05-09-2006 07:29 PM
Body off question... joeford Hotrodding Basics 1 05-07-2006 07:26 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Model A body dimensions Help! NZ30Roadster Body - Exterior 3 02-19-2005 06:52 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
