Powerglide leaking/acting funny ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2005, 09:17 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I'm asking for my buddy.
He bought a GER powerglide & converter from a fellow.
It supposedly ran fine but sat for two years in a car before my buddy got it. So he calls me tonight {like I know about powerglides} and says he's got it in but...
On the first trip he said it acted like it was in neutral at the first stop sign he comes to in 1st but drive was ok. He said he was able to limp it back to the shop and pulled the pan...which was dirty {how dirty? i don't know}. He put a new filter in it and ran it thru the gears & reverse. Said it shifted firm and quick on the lift.
So he takes it for another drive and says now it's blowing tranny fluid past the front seal under load (700+ HP). The TH350 held up well so far, but it was just a matter of time so that's why he put the glide in.
So he pulled it back out and tore it apart looking for anything, espcially a plugged vent hole. He said he found nothing wrong besides the high gear clutch packs.
He is a really good mechanic but.... I'm thinking he didn't really get it full on the first run and that's why it acted like neutral. But would it still work in Drive and not 1st if it was low? and about the seal, It needs one of those "band-aids" that clips to the housing to hold the seal flush, correct?
So in the morning I'm supposed to go and help put that sucker back together. Is there anything I should look for? am I on the right track or do I need to look at the converter snout diameter? Is there anything in the VB or ANYTHING that would cause this besides what i just mentioned? I know it's late but I really need to know asap.
Really thank you for the advice fellars!
Old 07-07-2005, 08:07 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
could be many problems cause this. the low fluid sure sounds like a good idea when the tranny would not move.
Air check the drum , band servo for leaks
Old 07-07-2005, 01:26 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
sounds like a fun car, out of curiosity, what is it (not to thread jack)?
K
Old 07-07-2005, 06:33 PM
NXS's Avatar
NXS NXS is offline
Killer, it's that heavy Elky.
Refreshed it today, found nothing wrong besides the clutch packs? It works good now and the trans brake is working. very odd? Thanks for the help Crosely.
Old 07-07-2005, 10:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Good luck with the GER rpoducts
Old 07-07-2005, 10:34 PM
NXS's Avatar
NXS NXS is offline
Not my choice, I would have kept the Darryl Younger th350.
Good God I'm bored! Read this or die, its funny. killerformula Off-Topic 30 05-06-2009 01:08 PM
th350 and powerglide chrismac Transmission - Rearend 2 03-18-2003 02:22 PM
Powerglide, strength, conversion and misc' Venturat Transmission - Rearend 5 01-21-2003 07:59 PM
Powerglide, strength, conversion and misc' Venturat Engine 1 01-21-2003 09:52 AM
powerglide to 2004r thedez Transmission - Rearend 1 06-11-2002 06:44 AM
