powerglide low gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2010, 04:55 AM
powerglide low gear
i have a powerglide with a 1.82 gear ratio. my question is to any of you advanced math guys is, if i keep it in low and run aprrox. 26 inch tires on a 3/8 mile oval track... what rear end gears would put me at 6900 r.p.m max running low with a 9 in rearend?
Old 04-16-2010, 07:55 PM
ericnova72's Avatar
More for Less Racer
No way to determine this unless you give us the mph you want to be running at that 6900 rpm limit.
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 07:12 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
stuck in low gear tsw5013 Transmission - Rearend 4 01-17-2006 09:48 AM
BBC cam gear problem 454C10 Engine 4 12-14-2004 02:07 PM
