Powerglide problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2008, 09:33 PM
58lincoln's Avatar
Last journal entry: New (used) 350.
Powerglide problem
Hi I have some questions about my powerglide in my 1976 nova. First off is it even a powerglide? I'm not sure if they made powerglides in '76. the shift pattern is 1-2-D on the floor console & gauge pod. If it is a powerglide it has a 250 straight 6 up front. Is it possible to use this tranny with a 283 after I change the flexplate and motor mounts? What else do I need to change out?
Thanks.- 58lincoln.
Old 11-25-2008, 04:41 AM
It is not a glide if it is stock it will likely be a th250 not very strong trans but may hold up to a 283. It will bolt right up.A better option would be to find a th 350.
Old 11-30-2008, 08:46 PM
58lincoln's Avatar
Powerglide problem
Thanks barnym17. I'm on a budget so I think I'll just use the th250 and try not to beat on it.
« TH350 woes | 4t80e »
overcharging problem on 1972 mustang DaSouthWon Electrical 6 08-27-2008 08:17 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 12 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Powerglide Transmission problem ?? Velyx21 Transmission - Rearend 2 12-12-2004 07:37 AM
