powerglide question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2007, 07:43 PM
powerglide question
Hi, I have a 65 impala with a 327 and powerglide. Problem is the fluid is brown in color and smells burned. I got the car 5 years ago and replaced the filter+fluid a couple of times and it always shifted fine although the fluid is still brown/burned. I would like to purge the burned fluid out of the trans but don't see any way of doing this since there is no drain on the torque converter.
Is this something a backyard mechanic can do without a large investment in equipment ? I am thinking about replacing the trans with a th350 which will cost around $800 but want to determine if the PG really is trashed first.
Any ideas comments would be appreciated.
Thanks
otg
Old 04-08-2007, 07:49 PM
slip n slide with a powerglide
Thanks
otg
Sounds like the glide is finished. A rebuilt 350 w/ shift kit would be a pleasant improvment. Jerry
Old 04-08-2007, 08:35 PM
I was thinking that that a powerglide that old had a plug in the front of the torque converter. Have you turned the converter all the way around while looking at the front of it? If it doesn't have a plug, you can always disconnect the transmission fluid line going to the radiator, the one with pressure in it with the engine running, and run the engine until the fluid all runs out. It should take about a minute. Don't run the engine any longer than necessary to run the fluid out.
Old 04-08-2007, 08:44 PM
DeathRattle's Avatar
Some Punk Kid
I cannot be the only one that has seen/done this. This is really ghetto and somewhat wasteful but in a pinch with no money this has saved me in the past.
Not best way of doing this, better you have a machine do it.(thats my disclaimer)
Two fittings with some long rubber hoses. Two five gallon buckets or whatever you got. Capacity of fluid plus 2 or 3 extra quarts.
Start up motor run it threw gears till new fluid is gone.
Get an extra set of hands to help out or just have it professionally flushed.
Old 04-09-2007, 10:19 AM
unfortunately the converter doesn't have a plug which would make it easy.
Thought about using the cooling lines but with my luck I would really end up
with a toasted trans.. Question remains how can something that is cooked still work with no real problems. I am going to get it cleaned out and see what happens. Fingers crossed. Thanks for the input.
Old 04-09-2007, 10:13 PM
wyomingoutlaw's Avatar
back in the early '90's Hot Rod Magazine did a series of articles where they tested all of the popular automatics as well as some 4 speed muncies and saginaws, and some others that I can't think of off hand. the powerglide was the most efficient, and also weighs about 1/3 as much as a th350. if I can find the articles I will post a link. kinda off the topic I know, but I don't think a 350 is an upgrade from anything.
Old 04-10-2007, 09:47 AM
Interesting point. Newer may not always be better. For giggles, I may just check to see what a PG rebuild would cost. My son said that I woun't see any difference over 30mph. All I am "missing" is a first gear. Thanks.
Old 04-10-2007, 02:51 PM
The upgrade of the TH350 is the extra gear. I can live with the 2 I have in my PowerGlide but wouldn't mind a 200R for the gas mileage at today's almost $3 a gallon rates.
Old 04-11-2007, 07:51 AM
Wonder how much a 200R swap would be. What is this a 5 speed ? Sorry been working old muscle for way too long. My newest vehicle is a '78.
Thanks
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
