Powerglide question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2008, 06:14 AM
59ChevyRat's Avatar
Drive'um fast, Burn'um Hard
Powerglide question
I have a 2spd powerglide and I am trying to figure out if it is a 1.82 or a 1.76. The trans came out of an early 60's duece. Thanks
Old 12-05-2008, 02:10 AM
junior stocker's Avatar
Powerglide
If it's from an early 60's Chevy II (duece), then most likely it was behind a six cylinder. Are there 4 large holes in the transmission bellhousing? If so, it WAS behind a six, possibly even a four banger, the 153. If it was behind a V-8, and it was a two barrell carb engine, then it's still the same. 4, 6, small lopo V-8 makes it a 1.82 first gear. You can also pull the input shaft out (there will be a small brass ring on the end that was in the trans, don't lose it), if the shaft measures 12.625 or 12 5/8 inches it's a 1.82; if it measures 12.875 or 12 7/8 inches it's a 1.76 unit. The 1.82 unit will be a 4 pack direct clutch, but can be easily upate to a 5 pack with a hub change. Some of the hi perf/police/taxi Powerglides came with a 5 pack direct, but it's best to still get rid of the cast iron hub and go to a steel one; they're also made in billet aluminum. There's a ton of aftermarket stuff made for these transmissions to really strenthen them for racing purposes. Butch/56sedandelivery.
Also, If the trans is 28" long, it could have come from a 62-67 Chevy II/Nova,full size car 65 on, or 62 327 engine pickup truck. The 62-64 cars had a 25" long Powerglide, and the 62 aluminum glide ONLY came behind the 327, the other engines, 235,261,283 had cast iron units. After 63 all Powerglides were aluminum, and there was even an odd ball "Powerglide" that was a full manual shift unit they called a Torque Drive, but even it was just a simpler Powerglide. Also, after 65 1/2, the rear pump was deleted and they changed to the fine spline (ie. TH 350 style yoke) output shaft. Butch/56sedandelivery.
Old 12-05-2008, 06:27 AM
59ChevyRat's Avatar
Thanks for the info. That will give me a place to start. The guy I got it from had behind his 350 and he went to a TH350. I have decided I want to run a 4spd in my truck so I am going to be getting rid of it. I just have heard that question asked before and thought I would see what I could find out about it. Thanks.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
2 speed powerglide trans 64r1 Transmission - Rearend 2 08-03-2007 10:29 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
