Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powerglide question
Old 01-02-2013, 04:56 PM
RatPin RatPin is offline
I'll try that. So it appears the cast iron powerglides dont even have removable oil pans, so the most service I can give it really while keeping it in the car would be to drain the fluid, remove side plate and clean screen and replace seal and fill it with fresh fluid. Anything else? Will it matter if I put a shallow bolt in the hole for the torque converter to seal it off?
