Powerglide removal from 68 bird - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 06:29 PM
smily1's Avatar
pontiac nut
I have the x-member and all housing bolts removed. I have a jack under the trans and have pulled it back. Here is the problem: The torque converter is still bolted to the flywheel and the trans does not have enough room to slide the shaft out of the TQ converter to completely remove. I tried to separate the TC from the Flywheel but dont have enough room to loosen the bolts.
I am missing something here. What is it?
Old 05-29-2006, 06:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you have to unbolt the converter..
I've done it that way for decades.
What is in the way of removing the bolts on the converter?
Old 05-29-2006, 06:56 PM
smily1's Avatar
pontiac nut
I can get a wrench in there but it wont budge. I have air tools but dont have enough room to use them. I may have to try again.
Thanks for the input. At least I know where to focus my energy.
Old 05-29-2006, 07:01 PM
poncho62's Avatar
Wiki Edits: 5
Longer wrench......better leverage.........a bit of penetrating oil.
Old 05-29-2006, 09:02 PM
njbloodline666's Avatar
I Love VTec
they may have loctite on them, i dont know if they did it at the factory,but if the trans has been out before they might, i just use a small mapp torch and heat them up, put the wrench on it give it a few whacks with my palm and they come right out
Old 05-29-2006, 09:09 PM
Powerglide removal from a 68 bird
A 68 bird ?
What 68 that came with a Powerglide is a bird ?
I know of ........
Nova
Camaro
Biscayne
Bel-Air
Impala
Corvette
Corvair ???
Chevelle
Old 05-29-2006, 11:05 PM
smily1's Avatar
pontiac nut
Originally Posted by Deuce
A 68 bird ?
I know of ........
Nova
Camaro
Biscayne
Bel-Air
Impala
Corvette
Corvair ???
Chevelle
Mine and many others.
Thanks for the tips njbloodline. Ill give it a try.
Old 05-30-2006, 06:29 AM
Will I ever get it done?
Last journal entry: Hood
Super Turbine 300
Old 05-30-2006, 07:11 AM
poncho62's Avatar
Wiki Edits: 5
A 68 bird ?
I know of ........
Nova
Camaro
Biscayne
Bel-Air
Impala
Corvette
Corvair ???
Chevelle
I think he means "Firebird"
Old 05-30-2006, 11:53 AM
YES ... ... but Firebirds do NOT really have a Powerglide ...
Old 05-30-2006, 10:37 PM
smily1's Avatar
pontiac nut
Thanks for the help folks. I had to buy a 6 point socket and a 3/8 non ratcheting wrench for the tight space. All went well. Now I get to fit the t-350 in there...
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
68 firebird into a 68 camaro? pi71 Hotrodders' Lounge 14 11-30-2009 07:24 AM
68 Chevy Impala or Honda Civic rpierce77 Introduce Yourself 5 01-08-2007 08:27 PM
powerglide tailshaft removal brian12c Transmission - Rearend 1 01-04-2006 08:07 PM
68 charger trim removal......HELP!!!! evilone Body - Exterior 5 04-20-2005 03:32 PM
