powerglide reverse problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2010, 07:03 PM
ok i have powerglide all gears work fine but when in reverse, it will not idle back unless the front tires are completely straight and if they are turned alittle I have rev the motor up to like 3,000 rpm to get it to move. any ideas what could be wrong maybe band needs adjusting?
Old 03-20-2010, 08:18 PM
Band is low gear, does fluid smell burnt? Stall converter? How many miles on it? Shifter out of adjustment maybe, burnt reverse clutches, etc.
Old 03-21-2010, 01:32 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You need to pull the trans. to check it out, the reverse clutches are at the rear of the case, inexpensive & easy to do.
Rich
powerglide transmission problem dragster477 Transmission - Rearend 5 04-15-2009 09:46 PM
4L60E Reverse Issue jgarced Transmission - Rearend 6 02-24-2009 09:23 PM
Yargh, carbureator problem is driving me nuts (but not my car!) caustic meatloaf Engine 12 05-21-2006 01:41 PM
TH-350 reverse problem. Eric327 Transmission - Rearend 5 03-28-2006 07:08 PM
Engine stalling problem JamesRS Engine 3 01-30-2006 12:22 PM
